first off, I would try to stay away from the fire hose. Thats to much pressure, the pressure is going to either make a hole or find one to cause problems.
here are a few things to check and do. grease every electrical plug you can get your hands on with die electrical grease including the sparkplug boot. Plug the carb drain, extend the carb vents up to your pod and check you gas tank vent and make sure you havent filled the stirring stem up with water from the fire hose.
