1 - 14 of 14 Posts
Starts great cold or hot out. When at idle it sounds normal give it more gas and it starts this loud slapping tapping sound and goes away when you return to idle. Adjusted the values to spec and didn't seem to help. Please HELP
Is the carb all adjusted properly? Could be like wrong fuel-air mixture or something, fuels to rich or there's not enough of it coming through, I had a similar sounding problem and that fixed it, also if there's a bit of blockage in the muffler it could limit the amount of exhaust being able to escape so it struggles and might give you something similar, where's the noise coming from? Can you find it possibly?
Discussion Starter #4
Yes It takes gas good and it did sputter at idle till I adjusted the air fuel
check the muffler if you have some blocking the flow and making the tapping sound?
I had a muffler go bad on 02 foreman and lost all power due to exhaust restriction.
would idle fine but try to go someplace and the engine would bog down due to the restriction.
Temp fix was to insert long rod into muffler to keep the broken/rusted baffle out of exhaust path.
Long term fix was to put a new muffler on it.
best of luck to you.
Discussion Starter #6
[QUOTE="sublime68charger, post: 3187610, member: it runs great and has power it doesn't bog shifts good, one way bearing is good I changed the push rods last night thinking that maybe in a crazy way it might of been them, the bike only has 1600 miles on it
how many miles/hours on this machine?
how long have you had it?
I'm not much of a ATV Mechanic but those anwers' may help others who have more knowledge.
Discussion Starter #9
Go
Literally 1600 check the timing chain the tension the valves and pulled the cylinder off and checked for play in the rod. Can't find a single thing don'tknow if thats good or bad lol
Hi, everyone. I have similar problem. I am completely new in ATVs and just bought a used Honda Foreman TRX450S 2003 with 700 miles on it. It drives great but has similar weird noise also
Is "lifter bucket lifter valley" part of timing chain tensioner or its separate part? Where I should look for it? Sorry for my newby question. Please, help.
I am trying to google "lifter bucket lifter valley" for Honda Foreman and can't find anything. I need more clarification what part is that and where it is. Please, help.
1 - 14 of 14 Posts
