We have been having the same issue- we have discovered its all in the connectors the box plugs into.I have an 04 450 ES and the fan doesn't work. I grounded the sensor wire to the motor and the fan will come on but blows the fuse everytime. Anyone have an idea what could be the problem? Thanks
Mine was out also. 12 volts to fan to make sure is working. Then I replaced all three sensors. Oil, air, and control box. all is working now. Good luck.I have an 04 450 ES and the fan doesn't work. I grounded the sensor wire to the motor and the fan will come on but blows the fuse everytime. Anyone have an idea what could be the problem? Thanks
