Can I get information on a fix for my 04 Honda foreman es. It was a wrecked machine I am fixing up. The screen lights up and shows mileage and mph but both way higher than correct. The gear selector part doesn’t work but the clock and other things work. Just showing number too high. Can you help me?For those that have been pulling hair out-
It took me a month to figure this out, but I am glad to report that I have figured out how to repair my 2004 450ES Speedometer
If you have a 02-04 450 ES model ( 4 indicator lights on top of meter)
or a 99-00 450 ES model ( 3 indicator lights on top of meter)
and your display:
- does not show the gear indicator spot at all (not the gear or --) but the
backwards "L" that goes around the gear position - its just blank
-your miles and hours have reverted to zero and possibly now shows KM now instead of Miles
-your speed shown seems to have almost doubled (possibly KMs per hour even thought it shows Miles)
What has happened is your EEPROM chip on motherboard has lost the programming due to dead battery for
a LONG time or an electrical malfunction etc...
I have borrowed a friends speedometer (a trusting friend) removed the chip from his, copied the data and put it on mine and it reads perfect now.
I can repair and reprogram your speedometer
I can also do 99-2000 450ES speedometers (3 indicator lights on top of meter) but will have to double-check check on the mileage/hours copy I have and let you know to see if you want that
I can also do TRX500FM and FE meters and the older Rancher 350ES meters as well but it has to have the above symptoms and not water damaged-caught on fore cracked lcd etc....
If you have one you want to send to me (just the board with LCD) I can repair it for you for 85.00 or if you have a second speedometer for parts we can barter for 50.00
Shipping would be 6.00-7.00 First Class with tracking or $8.45 for USPS Priority Flat Rate Small box with tracking and 50.00 free insurance
I will confirm and send pictures to you as well to show you the completed repair
If there is heavy water corrosion, rust etc.. its probably not repairable but I can try if you want -no fix-no pay
If you PM me or whatever we can work it out I am easy and like you all I am always fiddling/learning with wheelers
I think you will be happy and you will have more hair -mine is filling back in...................
I have this exact problem on my 2004 TRX450FM A Foreman S. The green neutral and red reverse lights work). No indication of the gear I am in and that area of the meter is not defined (No backwards "L" as you described). Everything else is perfect. Which part of the meter do you require?For those that have been pulling hair out-
and your display:
Ask him over at atvhonda.comI have this exact problem on my 2004 TRX450FM A Foreman S. The green neutral and red reverse lights work). No indication of the gear I am in and that area of the meter is not defined (No backwards "L" as you described). Everything else is perfect. Which part of the meter do you require?
I have 2000 Forman 450 es Goes in and out and don’t work properly can you fix thatFor those that have been pulling hair out-
and your display:
I can also do TRX500FM and FE meters and the older Rancher 350ES meters as well but it has to have the above symptoms and not water damaged-caught on fire cracked LCD etc....
If you have one you want to send to me (just the board with LCD) I can repair it for you for 100.00 or if you have a second speedometer for parts we can barter for 50.00
Its not as cheap as I would like it to be but it beats paying 250-400 for a new meter if you can even find one, as most are becoming no longer available and when you find one on ebay it usually needs the Polarizing films and/or reprogramming as well
I have a 1998 TRX450 EZ 4x4 with sun damage can I get a quote on getting it fixedI sent you a message if you would like to contact me we can get you fixed up
My 98 foremanES is showing 0hrs and 999,999miles. If i have it fixed will it show the accurate miles and hrs? I’d like it to be accurate. But i don’t know those numbers.For those that have been pulling hair out-
and your display:
