1 - 1 of 1 Posts
Ok my 420 will not run here list of what I’ve done
I’ve check timing it’s on time
I’ve put new spark plug in got white spark
I’ve checked valves they where little tight so I set them to factory settings
I’ve check fuel pump and fuel line it all good
I’ve tried starting fluid and it will not even run on that I’ve read somewhere that an bad coil can cause it to not run at all and have spark but that don’t make any since since it does have spark it should run if anyone can help out that be all some
1 - 1 of 1 Posts
