I had to disconnect the pcm and other wires to remove the back rack. After reinstalling the repaired rack and connecting all the wires the "engine light" flashes, engine fan runs, and the ES doesn't function and the engine only idles. The "N" flashes. I took everything apart and cleaned the posts, added "electric grease" and plugged everything back up and the "engine light" didn't flash and the fan stopped running (engine cold). I noticed I didn't have a connector clipped into a mounting clip so I clipped it in and turned the switch and I was back to square one...fan running, engine light flashing and no ES. I can not seem to find the proper wire/harness that is the cause. Any suggestions would be greatly appreciated!!!!
Thanks in advance.
