1 - 1 of 1 Posts
Looks like my ring gear on the wife's 420 has stripped the splines.
Went for a short cruise yesterday and noticed that I had one roostertail coming from the right side. Left side isn't pulling anymore.
Sooo, that means stripped splines on the ring gear and likely on the CV as well.
Anyone know if the 09-14 and 15-up rear diffs are interchangeable? They look the same, but looks like the later ones have slightly different bearings in them so they aren't EXACTLY the same. I'm just wondering if the mounting points are the same where one would bolt in place? Ring and pinion tooth count is the same so gearing would work fine.
@toodeep, you happen to have any idea?
1 - 1 of 1 Posts
