There are 2 types of blink patterns to determine the code. A long blink and a short blink. Long blinks are x10 and the shorts are the number of actual blinks.
Ex. 2 long blinks and 4 short blinks gives you a code 24 (2x10+4=24).
I thought I posted this already but must not of..so here it is.
I had a machine come in today with multiple problems. Code 24 was one of them and it turned out to be a dirty shift motor (brush was stuck). I had time and took some pics.
Remove the shift motor from the engine and then remove the 2 allen bolts, proceed to take the shift motor apart.
Inspect everything and if all looks good proceed to clean it up for reassembly.
It's easiest to clamp the brushes to hold them open while installing the armature. The springs will fight you in the small space.
Install the armature and release your clamps. You will want to lightly clamp the teeth part of the armature in a vise or use a pair of vise grips or the magnet will pull it out and you have to start over again.
I use a little dielectric grease around the rubber washer and install the housing. Tighten the allen bolts and your ready to go.
took apart the motor, cleaned it, pluged it in and hit the shift button, it worked, put all gears back and it shifted into 3rd and then 3 or --- was blinking 3 times, can't get trans to hand shift out of third to N.
joe
How did the shift motor look on the inside? The 4x4 could be flashing be cause of a low voltage signal, which could be caused be a faulty shift motor if it was bad enough. Have you shifted through the gears (all of them) manually just to make sure it isn't another gremlin?
I had trouble with it blinking codes a while ago....turned out to be one of the brushes in the starter wash stuck. Also had trouble after that off and on, mostly on wet days. I waited until all was working good and sprayed all of the electral connections down with fluid film. Never had another problem with shifting after that.
I have recently purchased an Honda ES bolt on shifter from ACE's in Meridian, Ms. We have installed it on our ATV ourselves and has made all the difference in the world. It has fixed all our problems. You can contact them at [email protected] or call Tyler @ 601-616-3299.
Also i purchased for $50.00 with free shipping. Hope you find your answers. Crystal
Alright we’ll I’ve looked around and it seems that I’m having a weird problem I replaced my angle sensor in my 05 rancher 350 and it still won’t shift the shift motor is good and I unplugged the ecu and the quad will still run so I don’t even know what to think unless that’s not the ecu under...
Hi, I have a 2005 TRX 350,ES / FE 4x4 that as the title suggests I want to change to ES system to a manual foot change.
The reason I want to change it is the system in dead ! I bought the quad as a fixer upper. Its done very little work but was used as a grit spreader for two mild winters...
I have heard there is a kit or something you can get to change an electric shift over to a footshift. My son has a 02 rancher 350 and the electric shift is out. changed angle sensors, worked for awhile then out again. I need my head examined for getting another electric shift for him, he had a...
2013 4x4 ES. Has 8000 miles. Turned it off and won't start since. Turns over with the button.
Here's what I've done:
Yes, kill switch is off.
New spark plug and coil. Will spark when held against the frame once button is pushed.
New battery.
Broke the injector yoke when trying to see if fuel was...
Recently my bike started to have a rough idle (almost die), and when throttle applied the rpms would hang up a few seconds. I cleaned the carb and now the bike idles great, but as soon as throttle is applied it dies. I began looking for the problem
Steps taken:
1) Confirmed all jets are clean...
