i don't have aftermarkets right now, but with aftermarket rims you could have offset, which would effect the tires place relevent to atv, moving it in or out, keep in mind the center of tire is usually taller than out side.....most people hammer there fender mounts allso so they sit closer to the fender, i have stocks and i bent mine so bad on a tree stump that i had to hammer it back. easy and cheep option. also tire pressure has a huge effect on low pressure atv tires, people that want a taller tire sometimes put more air into it ganning an IN on dia. my .02 on the sub, hope it helps
bowz
