I just bought a fourtrax foreman 520 and need to stiffen up the rear suspension. Stock load capacity is 176lbs. I have a water tank that sits on the rear that I put 30 gallons of water in at times and weighs about 240 lbs. It has a Showa HR4-A21 rear shock that has been placed on the stiffest setting, still not enough because I am 60lbs over capacity. I have done research and found where they suggest a heavy duty spring, spring spacers or a new shock. Problem is I could not find anything that is made specifically for my atv or shock. Does anyone have data on this or a company that makes heavy duty springs or spacers that fit my set up? I have looked at several, including HighLifter, and am not sure what will fit or work for my atv or specific need. I do not need to add height, just want to prevent the rear end from sagging under a load. There just doesn't seem to be information or parts available for my needs on the internet. Model TRX520FE2N. Thanks
