There is a recall on these, should be a N/C repair.
We had both of ours done, but we only had a couple hundred miles on them when this came out.
Everything else was fine on ours, just the hard shifting when using the Auto DCT. We only had a couple hundred miles on them at the time, so after they did some testing, there was no damage done.Was there mechanical damage?or did you only do a pcm update?
Took less than 1 hour. Since my Rube has less than 400 miles on it we decided not to check the components for wear. I also was not keen in removing the engine and opening everything up. It never made any kind of noise. I purchased the extended warranty through 2025 anyway so I'm covered.Taking my 2021 FA7 in tomorrow for this. Had the double dash on the gear indicator a few times especially when plowing the driveway. It always reset by turning the key off and restarting it. Thx for posting the bulletin.
I don't see why not, a recall is a recall, regardless, they will get paid for it from HondaSo my 21 520 (400 miles or so) I noticed isn't exactly the smoothest shifting in auto DCT. I've never had any grinding noises or slipping out of gear or dash indicator lights, but I'm wondering if my dealer will perform this update anyway just as a precaution?
My dealer said it was free.So my 21 520 (400 miles or so) I noticed isn't exactly the smoothest shifting in auto DCT. I've never had any grinding noises or slipping out of gear or dash indicator lights, but I'm wondering if my dealer will perform this update anyway just as a precaution?
So dealer called me back yesterday and apparently the VIN #'s it was for ended well ahead of my VIN #, so in other words mine wasn't applicable.My dealer said it was free.
Well, the Service Bulletin says - ALL VINS ?So dealer called me back yesterday and apparently the VIN #'s it was for ended well ahead of my VIN #, so in other words mine wasn't applicable.
Good point. When the guy called me yesterday he said something like it only pertained to a certain range of VIN's and it ended way before mine. I wonder if he was just blowing smoke..Well, the Service Bulletin says - ALL VINS ?
