Hey folks, I've been looking into my issue on a few forums with zero luck so I figured I'd post here and see what you guys think.
I'll start with machine details. 2019 rubicon 500 deluxe with 165 kms on it. We went riding a few weeks ago and the trail had flooded, long story short I hydrolocked the quad. I pulled the plug and removed the water from the cylinder and got it running again, loaded on the truck and it's been sitting in my shop while I was away for work.
Yesterday I did multiple flushes until the oil coming out was clean. I put everything back together and fired the quad back up. It was misfiring pretty badly I checked spark and it is good. fearing I had bent a valve I pulled the head and valves and inspected them. Everything is straight so I reassembled the top end with a new plug. I fired the unit up and the misfire is still there in neutral but it goes away in drive and reverse and sounds as it did before the incident.
After testing a few times I recieved a code "23" on the HUD which is an o2 fault to my understanding. I pulled the o2 out and it looks fine but I'm not sure if maybe some water got into and wrecked it. I have read a few different places that the o2 sensors are a pretty common issue.
I know the o2 would control timing and afr but I cant see how within the 2kms it rode back to the truck it would have been off enough to cause this misfire as it wasn't doing it on the way to the truck that day. I could very well be wrong there though and was wondering if anyone had any input on my situation. Thanks in advance
Did you check for water in the connection? all connections should be checked and cleaned as needed then ad dielectric grease to every connection before you connect them. Not sure why Honda doesn't call for this. My dealer does it to all his machines to save the electrical headaches later. good luck man.
Yes, I have all the plastics off the quad right now so I've unplugged everything and added die electric. I am leaning towards the o2 sensor at this time but don't want to fire parts at it until I have a chance to dig a little deeper
Any luck finding the issue?
I'd check the battery and fuses they can cause strange things to happen. That code could also be an angle sensor issue.
