I have a 2018 rubicon with eps and manual foot shift. The 4wd light, diff lock, and check engine light are flashing and the speedometer quit working. Any suggestions?
Sounds like a bad ground. Start at the Battery. Make sure all Connections are Clean and Tight. Gently wiggle and twist the wires leading to the fusebox. Remove and re install all the fuses. See that the blades are clean and not corroded. Move up to the Dash Pod and do the same.. Keep looking. Keep us posted...
