1 - 7 of 7 Posts
Hi all,
2017 Rubicon 500, EPS, DCT. Just adjusted my valves, but as soon as i started it, it was ticking worse than before. I have about 3,300km on it. I tried putting it at TDC using the timing plug, but could not see any timing mark. I've read that there is supposed to be a ''T'' on the flywheel or something, can anyone confirm this? I used the method of putting a zip-tie through the spark plug hole and cranking the engine by hand till it goes all the way up and both rocker arms are loose but this might not be precise enough. Can anyone confirm which size feeler gauges are to be used? Any tips would help!
Thanks!
Haven’t worked on one that new, but I generally have to use a flashlight and turn the engine quite slowly to find the T on a Honda.
That being said, the base circles on modern cams are pretty consistent. Valve gap is likely the same when the piston is anywhere close to top dead center between compression and power stroke.
Was just wondering how the valves were before you changed them - too tight and you loosened them? Were they already loose? Sometimes a properly adjusted engine still sounds like it's ticking, but that's normal. Don't forget that things change as an engine heats up, that's why you should always do adjustments on it cold.
First tiem I made it the same :-( It's wrong. You probabely adjust valve clearance at wrong position!!! The ''T'' sign on the flywheel can be at TWO piston positions. You have to find the right one for valve clearance adjustment!!!
This is in manual:
Make sure the piston is at TOC (Top Dead Center), the "T" sigh" on the compression stroke. This position can be obtained by confirming that there is slack in both rocker arms. If there is no slack, rotate the crankshaft clockwise one full turn and match up the "T" mark again.
Discussion Starter #5
Thanks for your replies, I recently purchased the atv and it sounded, mostly upon downshifts, like it was ticking slightly. Upon inspection I found that the Intake was slightly loose and exhaust was too tight, hence why I decided to readjust them. I’ll try again with a second person cranking because trying to crank slowly by hand while looking in the tiny hole is annoying to say the least.
Put your finger over the spark plug hole, to confirm compression stroke. TDC on the top of the compression stroke, in other words piston is coming up the cylinder with both valves closed and is pushing air out the spark plug hole. Then check timing mark...
Discussion Starter #7
Thanks, did this exactly, still dont see timing mark but rechecked with feeler gauges, i really do have the right specs. I called the dealer and what they suggest is taking off the hand crank and turning the engine with a ratchet, but im not doing this as id have to take a whole bunch of parts off. Again, i checked the clearances before readjuting the first time, and the exhaust was really too tight, so my theory is that i was not hearing much if any ticking, and now that they are properly clearanced, im hearing the ''real'' engine sound, which ticks more than it was before....
1 - 7 of 7 Posts
