Hey first time posting on here looking for help! My 2016 foreman rubicon dct eps seems to be stuck between gears was running fine all day, then went to head back to shed and it wouldn’t shift to drive got stuck with just the - in the gear selection spot. It’s not flashing as I’ve seen on other posts just steady - could t get it to shift back or ahead with anything I’ve tried hoping someone has an idea what it might be? Thanks a lot !
I have my 20 Rub does that and I just cycle it off and on a few times. Stepped down and moved it just a bit while it was shut off. I think the last time it did it I shifted down and it went into 2nd, hung 2/3. Rocked it and it shifted on down to neutral. Mine does it worse when it is cold and I am just putting around...
