2014 foreman intermitent electrical issue,sometimes no power to dash or starter . You can loosen positive cable ,then retighten and it will work 5 or 10 times ,and no power again. Loosen ,than retighten again ,and it will work again. Cables are not corroded ,and are tight . Battery in at about 13.4 volts. Any ideas ? Just started doing it out of the cold blue ,no pryor symtems. Is there a relay that is reseting when the power is removed ? It acts as though the batery has been removed ,when no power . No fuel pump relay ,nothing.
Thanks in advance .
Thanks in advance .
