1 - 1 of 1 Posts
My 2011 will idle up to 1/2 throttle and then it does not matter how much throttle you give it will not go any faster.
The valves have been adjusted and it has a new carburetor. It did the same thing with the carb I took off of it.The fuel line is clear, the fuel petcock is clean. A local mechanic said he thinks the cam is ground down and needs replaced. The cam chain should be replaced at the same time if the cam is the problem. Thoughts? I looked for a similiar thread and di not find one.
1 - 1 of 1 Posts
