1 - 1 of 1 Posts
I know this has been discussed a lot but havent seen my specific issue addressed yet so throw it out there too. 07 recon ES not working. getting code 3. changed angle sensor but still getting code 3. no click or anything from shift motor so can the shift motor throw a code 3 even though it does not indicate that? Also the safety switch on the right break seems to be out as it will not crank in gear even with that break pulled. The break is out and there is no tension on the lever but didnt think that would affect the switch. But could that switch somehow affect the shifting? doubt it but maybe. can manually shift through all the gear no problem. Shift motor seems to be good can jump and run it no problem but no power is getting to it. The main plug where the shift controls plug in on the battery side only has 1 port getting 12 volts and one port getting only 4 volts. Not sure if they should both be 12 or if 1 is actually low voltage or what.
1 - 1 of 1 Posts
