My timing chain broke. I rolled it to a concrete pad to work on it. Once there I took off the front cover to inspect and found out the timing chain broken. I replaced the timing chain and guide an tensioner. Once I put it all to together it will not move. It shows all the gears on the display but on each it will not move. When I put it in neutral it acts as if it is still tuck in gear and will not roll. However it rolled when the chain was broke. Am I missing something here. I took the front cover back off and all appeared normal. It does have a newer clutch.
Any suggestions?
Is it a Rubicon. TRX500 could be an air cooled Forman or a Water Cooled Rubicon. If it’s a Rubicon verify you have oil pressure. If the oil pump chain that runs off the crank out side of the timing chain is not on correctly. That would cause machine not to move. You can verify oil movement by running machine with a rag over the oil fill. If there is oil movement it will splash out the oil fill with machine at idle.
