1 - 6 of 6 Posts
Let me say that my bike has been awesome since I've owned it (2009) The thing has done alot of work for me over the years. Today I went to use it and when I turned the key on it was in 4th gear. I went to downshift it into neutral,but it wouldn't. I checked the shift mechanism and pulled it off to make sure it was working fine and it appears fine. I adjusted the clutch as per the manual and that doesn't seem to be the answer either. It did up shift into 5th and that's where it is "stuck" . Is there any ideas of what I may look for or does it need to go to trained professional? The bit of internet reading I've done seems to lean towards maybe a loose bolt somewhere? The link to identify this possible was defunct so that didn't really help me. Do any of you fwllow honda enthusiasts know what I might/should do next.?
Thanks in advance for your help.
Yep thats an old trick for sure....but that won't do it this time....im thinking it is something more....
Has the machine been sitting for a significant amount of time? Sometimes clutch plates can stick...
Discussion Starter #5
No. It was subject to a 17yr old......the shift fork plate is broke. I split the case and found it In two pieces. $120 in parts. AND a $150 specific clutch puller. But at least it wasn't anything too serious. Kids......when I ride it I don't get above 3rd gear, when he rides he can't past 3rd fast enough...hence the busted shift plate...
Figured either clutch sticking or someone romped on it and bent a shift fork, plate or related...
Glad you got it sorted.
  • Like
Reactions: Mcdougy1975
1 - 6 of 6 Posts
