1 - 1 of 1 Posts
Problem started after running through 18" of water. I get 5 blinks on the gear shift indicator and it won't shift. I can unplug the angle senor (also replaced it) replug it back on and the blinks will go away and the bike shift normally through all gears until you turn the switch off, then the problem is back.
A second issue occurs if you start the bike in gear. It's like it is stuck in two gears at the same time, it will try to move forward but you can tell something is bad wrong. If you put it in reverse, then start it in neutral, it will clear the "stuck gear" situation and be ok.
1 - 1 of 1 Posts
