Hello, my gear display shows "- -" and reverse and neutral light are on. i can hear it switch gears, but only r-n-1st as it is stationary, but it still doesn't show what gear it's in. when i manual switch, i get a display for a second before it actually engages into neutral slot. tried changing angle sensor, no go. checked wiring, seems alright. my next move is to replace gear position switch, but before i do i just want to see if any others have a possible solution. i have the rear swing bar off and am ready to take off stator cover.
[/QU
Probably a dumb question but is there enough going on the meter to give you any codes... if so that could send you in the right direction if you haven't...
I agree on checking the fuse, I have had this happen several times in the past
Its the first thing I check now if the Neutral and Reverse Light are on at the same time
If its not the fuse then it would be the gear switch most likely
Come on over to atvhonda dot com -free to join and MUCH better help and quick replies
