2004 Honda rubicon help
1297 Views 2 Replies 3 Participants Last post by  alex k
2004 Honda rubicon ~how much oil does this bike holds..I use 2 my transmission is making a wining noise & bikes moves but makes noise when giving half throttle & pulling like as the transmission is going out..this all started after oil change I only added 2 quarts(hondamatic transmission
There are two drains, one under the engine and another under the oil tank at the front of the engine. With both drained, you will require 5 quarts of oil, 5.2 with the filter changed.
Usually you can add 4 quarts, then run the engine a minute - then shut it down and add the last one.
  • Like
Reactions: 1
my bike has foreman and rubicon on the tank it is a 2004 500
