I’m having issues with my Honda foreman rubicon 500. I can crank it and it will run for an hour or two with zero issues. Then I will come to a stop and it suddenly dies. It will crank straight back up but will die when you give it gas. After several attempts it will finally pick up and go. But once again when you come to a stop it will idle but then when you give it gas it dies. I have no idea as to what it would be since it cranks right back up. I have tried taking the gas cap off no change. I’m lost as to where to go from there. Thank you ahead of time
I'm having issues with my 2004 Honda foreman rubicon. It will wrench and run fine I can ride it for some time and afterward I go to an inactive and it bites the dust wrench it back up and will take any stuff I put it in however it will falter when I give it gas I'm a forward stuff or opposite. At that point I walk out on and it disappears. I have no clue about what it is any assistance what it very well may be.
Kodi nox
