Hello, I'm about to take apart the front brakes on my 04' Rubicon. My question is my Hydraulic front lever has nothing, it goes all the way to the grip. I've bled it several times and am confident theres no air at this point. I just purchased this machine and was told that new shoes were just installed, which I'm doubting now , and that it was air in the line. So I tried adjusting the front adjusters and noticed that one would only turn 2-3 clicks either way and all the others seemed to move fine. Im going to pull it apart to check the cylinder but if I need to change one am I supposed to change all? Also, when I take this apart I've read that I need to replace the 4 bolts? Can I just Loctite these or is there some other reason to replace? Finally is it also a good Idea to replace the water/dust seal or is that also only if its bad or damaged. I appreciate any help before I do this. Also if I should know anything else that may help please let me know.
Thanks,
Ron
Thanks,
Ron
