I’m new here. Have 03 trx500fa 4x4 and it’s stuck in 3rd gear. When it happened it would rev as in 3rd but let go of throttle as to downshift it jumps and seeems as it is in 1st gear feeling making feel as if you downshifted straight to first gear bypassing second gear and bogs down real hard.
I’ve already checked angle sensor and checks 1852 on ohm meter. My next step was is check the gear shift sensor. Is this the correct route togo? Can angle sensor be going bad only putting out 1852 ohms. It’s range is 1600-2400 ohms. 2000 ohms Is would be the 1/2 way range the way I loook at it. Would greatly appreciate some help and insight to this. I have the service manual but doesn’t say exactly where things are and location. Please help. Ty very much in advance. Dennis
