1 - 1 of 1 Posts
Hi all,
Have a 2003 rubicon that we use on the farm. I put a new OEM carb on it because I thought the needle seat was too worn to shut off. Turns out the screen in the tank was compromised and it kept getting debris between the needle and seat.
Anyway, after installing the new carb the thing runs perfect for a while, especially if you're using it hard. But if you let it idle much after it warms up it will eventually die and then it usually wont restart until you let it sit for 15-20 minutes. Then it will be fine again for a while.
Seems to me like its slowly flooding itself. I'm about 3500ft of elevation. Could it just need the main jet changed? Any other ideas?
Thanks!
Max
1 - 1 of 1 Posts
