Let me start off by introducing myself, Im Nick, I'm 33 and work on small engines as a hobby/side job. Have a decent amout of experience with atvs, dirt bikes, small engine repairs. But I am new to this hondamatic transmission, never worked on one or serviced one before.
A friend of mine brought me his 2003 Foreman Rubicon 500 that has what appears to be transmission/clutch issues. ATV runs fine, but won't move no matter what gear you select with the lever, wether it be in D1, D2, or ESP. He claims he rode it into his shed, shut it down, and the next time he went to use it he started it up and could barely get it into gear using the shift lever, and then once he got it in gear the lever wouldn't move back out... (It came to me still in reverse but I managed to get the lever back to neutral). Its been maintained relatively well from what I can see, and the engine oil was very clean and up to spec on dipstick.
I scouted this forum for a while, and have seen some threads mostly talking about oil pressure failure due to the oil pump chain coming off. After researching a bunch I figured out that the hondamatic obviously needs sufficient oil pressure to operate correctly. I also saw some videos on how to retrieve "Codes" from the dash indicator, so I went ahead and did that and only got a Code 11 (which could be a number of things, ECM Relay Code). That could be a weak battery, who knows how long that code could have been stored. After reading countless forums I decided to start with checking the oil pressure check valves and springs. Took both oil pressure bolts out of the engine and only could get the springs out. Is there a secret to getting the oil check valves out?? Anyway, the springs looked good so I reinstalled bolts.
Today I tore into the front part of the engine to inspect and see what was going on exactly. I was really hoping to just tear the front cover off and see the oil pump chain hanging off, but of course that wasn't the case. Please note that I don't have the Honda oil pressure tool, so to check oil pressure before I tore the engine down I pulled off the oil lines going to the front tank, started the atv and let it idle and had no oil flow coming in or out of those lines at all. Kinda figured that meant no oil pressure and was sure that I was going to see a chain failure. Not the case.
I am now waiting on the owner to bring me the service manual tonight, also waiting on the puller to get the clutch pack off, and I ordered a new oil pump chain since im already in there. Upon inspection I took these pictures. It appears the clutch basket or outer ring has seen some heat, any thoughts? Clutch that worn to where atvs won't move? Also, there is some writing on the hondamatic...has it been replaced already?? My friend had bought this quad in 2016, and has ridden it this long without any issues.
Any input would be appreciated guys, what should I be checking? Anything I missed?
