1 - 6 of 6 Posts
Need to install new cable. How do I disconnect the old one from the carburetor ? Goes into what I suspect is called a plunger valve....Also what do I need to remove to provide adequate access to perform the removal ? Thanks in Advance !
Follow the cable to the carb, then you'll see where it enters it and there's a black plastic nut that you unthread. Pretty basic. Chances are, it will be difficult to access with the carb in place. Sometimes you can get by with rotating it after loosening the clamps.
Yeah, I usually do so. Just a light coating of grease. Sometimes moisture invades this area so cleaning & lube are a good move. Be careful when installing the nut, it's easy to strip those plastic threads.
1 - 6 of 6 Posts
