I took the rear case off the atv to replace the rear output shaft seal, and when reinstalling the shift rod doesn’t appear to be completely fitted in, when pushed it doesn’t move any farther in, but you can pull slightly out, then back in, but not completely in. Should the snap ring on the shaft be completely flush with the case? If so, how can I push that shaft back in? Do I have to take the front case off in order to realign that shaft into the gear? Thanks.
If the shaft pulled out then a washer probably fell down in the front case stopping it from going bak into place. Front cover has to be removed.
