Electrical shift worked fine for a few days but , when it did not, i used a foot pedal on gear shift lever, ( pull up for some gears and push down for others). Machine would not switch out of 1st so i tried shifting with the foot lever.
Turned off key in 1st and need N to start and the info panel come on ok and battery is ok and winch works.
Need manual gear shift t work before el shift will work. Tried a bigger lever on clutch lever which moves one direction (foward) but seems stiff and will not move when I pull it back. No change from 1st into Neutral to start
Told that the motor should start if i pull cord on motor but no result.
I tried shaking the machine ( worked once before) and it seems to be locked in gear so it cannot be pushed.
Any help appreciated.
For the heck of it did you try disconnecting that battery? Might sound stupid but worth a shot. Easy try. I've had mine lock up in R in the back of my pickup, and I couldn't get the lever to work it back. Disconnected the battery. Connected it and it allowed me to shift it back to N, using the ES. Could have gotten lucky. Worth a shot.
