1 - 1 of 1 Posts
Recently purchased a 15' foreman 500 ES, fueled it up at -10 degrees Saturday morning. Got it home threw it into the garage yesterday was 30 degrees, figured it was just fuel expansion due to the extreme cold. Let it run and drove it around the yard for a hour to run the fuel down some, this morning its still doing it. Fuel is below the plastic cross member in the tank. I'm thinking the fuel vent line off the tank does not have a tight connection at the barbed fitting and needs better hose clamps put on it.Also going to take a little fuel out of it so it isn't so full. You can see plain as day that it's leaking right were it hooks onto the frame of the machine. Anyone have similar problems? I've also got a 14' foreman 500 and never had this issue.
Any help or input would be great!
1 - 1 of 1 Posts
