I have an 08 Forman Trx500fe that typically runs good. It seems I have a short or bad component somewhere as it will be running fine and all of a sudden the main 30A fuse blows. I changed and installed a new OEM voltage regulator. The problem still occurs after the regulator was changed. I do notice it blows the fuse after it’s been running for 20-30 minutes. Once it blows the 30 amp main slot will remain “live” and will want to blow a new fuse even with the key off. Once it cools down, I’m able to put in a new fuse and it runs normally. I thought it was a short with movement but it now seems related to coming up to temperature and failing. Any thoughts? I’m at a loss.
