MANUFACTURER Honda
MODEL YEAR 2007
MODEL FourTrax® Rancher™ (TRX420TM)
M.S.R.P. Request a Quote
Engine OHV, wet-sump, longitudinally mounted, 1-cylinder, 4-stroke, fuel-injected OHV,
Displacement 420 cc
Bore x Stroke 86.5 x 71.5 mm
Carburetion 34 mm Keihin throttle-body fuel-injection
Transmission 5-speed with reverse
Final Drive Direct rear driveshaft
Suspension Front: Independent double-wishbone; 6.3 in. travel
Rear: Swingarm with single shock; 6.3 in. travel
Brakes Front: Dual hydraulic disc
Rear: Sealed mechanical drum
Tires Front: 24 x 8-12
Rear: 24 x 10-11
Length 80.9 in.
Width 46.1 in.
Height 45.2 in.
Wheelbase 49.4 in.
Seat Height 32.4 in.
Turning Radius 8.9 ft
Ground Clearance 6.5 in.
Dry Weight 522 lbs.
Fuel Capacity 3.7 gal.
Colors Blue, Red, Olive
