So I've gone through many things from replacing the injector, spark plug, ignition coil, fuel filter. I've got good fuel runs perfectly in every gear until I goto 5th gear then boggs down on me. If I slowly give it throttle it will gain up speed but will sputter sometime. If I mash the throttle it Boggs down. It only does this in 5th gear. Any thoughts?
Very similar problem here. Cleaned carberator and main and pilot jets thought I licked the problem. Had good flow out the fuel filter. Turns out screen inside tank was getting plugged. I can visually see all kinds of crap in my tank? Well bought my foreman used 6 plus years ago and never cleaned the tank. Waiting on rubber oring to clean tank/remove screen in tank. Hope this helps
