1 - 1 of 1 Posts
Hello all, 06 Rancher ES with TRX400fa engine is in fail safe mode with 12 flashes. I understand that to be Gear Selector Switch according to what I read. I am searching for parts and all I come up with is the gear position switch assembly, which is the button assembly on handle bar. I am thinking that is not the likely problem, but rather the switch sensor on the tranny. I cant find the actual sensor in diagnostic manual. Is the switch assembly on the handlebar the likely issue or is it the actual sensor on tranny? What is the proper name or part number for the actual switch if that is the most likely problem? Thanks in advance.
1 - 1 of 1 Posts
