My bike has slack in the steering both ways. Does anyone know what the problem could be???
L lasallen · Registered Joined Mar 24, 2007 · 21 Posts Discussion Starter · #1 · Dec 2, 2007 Only show this user My bike has slack in the steering both ways. Does anyone know what the problem could be???
eric · Registered Joined Nov 7, 2005 · 1,572 Posts #2 · Dec 2, 2007 Only show this user Try tightening the nut at bottom of stem. Take cotter pin out, put loctite on threads and reinstall w/ ~ 80ft/lb
B boss500 · Registered Joined Dec 31, 2006 · 404 Posts #3 · Dec 2, 2007 Only show this user mine came loose at the bottom too. My spacers cause more strain on the steering. Tightened it up and its fine now.
B Bigvick · Registered Joined Dec 7, 2005 · 345 Posts #4 · Dec 3, 2007 Only show this user Check all your tie rod ends, I had to replace mine a couple months ago.
V Vernon · Registered Joined Aug 13, 2006 · 94 Posts #5 · Dec 3, 2007 Only show this user yeah the nut on my steering stem came loose as well. got it tightened up and solved the problem.
C cutigers52 · Registered Joined Sep 10, 2007 · 12 Posts #6 · Dec 8, 2007 Only show this user I had a similar problem, turned out my tie rod was loose. Dealer fixed it and replaced the Mudlites since it had eaten a bunch of tread off of them.
