alrite unstuckable, ive read a few threads and post so far and i think i can manage to do this...i think ima just end up undoing the shocks at the top then undoing the brake lines, not sure why i would need to reconnect them since i have no rear brakes at all, or maybe i should just replace the drum brake pads while im working on it...but undo the brake lines, unbolt the 4 bolts on the diff that connect up then unbolt the bolts that hold the swingarm to the rear axle tubes and i think then it can be rolled out of the way...and the shaft should come out of the tube and everything...my swingarm has no play it in at all so i dont think the bearings need to be replaced on it yet
unstuckable is there any other bearings or seals that i would need to order when i get the u-joint? or is it just get the u-joint and everything else is good to go?
also how do u know if ur front bearings are shot on a bike? i have no side to side play in it at all, the only thing i have is if i jack the front end up i can turn the tire like 1/4" and then it will catch and start to spin the other side, not sure if that just means the bearings are bad or if there is just a little slack or play in it, rides like a charm so i dont think that is it at all
thanks for the help though
