When I was redoing the top end, i took off the carburetor and noticed 1 electric wire soldered to the bottom of it. I kinda ripped that wire off and was wondering if I have to re solder it on there or is there another way? Thanks!
Hi, i suspect it is pulled of very close and the only way to attach it is solder. I suspect it's on a brass plug? I believe it is a heater and in most cases will run fine without it or you could get a used one to thred in. Hope it helps
Thanks for the reply! I rode this weekend and it ran fine without it so I guess it'll be ok!
