Does the cpu need to operate for the bike to run properly or can i jump it out in some way....this is not about ECM its the LED display... im not getting speed odm. To work and yes i changed speed sensor and did service manual but when i check for voltage across blk/blu and ground i get no battery voltage and wire is ok i think the bat voltage comes from cpu/display and dont want to spend anymore on a new display
Historically with automatic transmissions a speed sensor is necessary to let it know when to shift. Otherwise you get stuck in first gear. That's how it is in cars not sure about our hondamatic.
