1 - 15 of 15 Posts
Hello all hope all is well !! I’m new and have a question about my 03 rubicon 500 , I just picked it up the other day used for cheap , but it has no spark and on the dash D1,D2and ESP are showing but only two dashes where neutral (N) should be showing , the guy I got it from said he was riding and it just cut off and has no spark , I have replaced the angle sensor ( followed the pre charge instructions) replaced the voltage regulator, still nothing !!! Any ideas would be awesome thanks !!!
Discussion Starter · #3 ·
I have tried to get it to show codes but i can’t seem to get it to show anything, I’ve looked online on how todo the correct procedure but still can’t get it to work !! Thanks for your response
Discussion Starter · #7 ·
I’m leaning heavily towards the cdi box due to no spark and the dash is not working properly!! Not N on the dash and I’ve tried the code thing multiple times and nothing I don’t even hear the noise that it says to listen for !! Thanks
It could also be the gear position indicator since you're not getting the N displayed. Sometimes this fools the computer when there's nothing wrong with it.
Always do electrical tests with a known, good battery btw.
Discussion Starter · #9 ·
Ok will get a new battery Thanks
Discussion Starter · #13 ·
01 TRX500fa Rubicon. I think my problem is the same too, same as 78rallys and mjohn. any news ?
I sold it but that guy that bought called me back and said he replaced the main computer and that it runs like a new one !! Hope this helps !!
thanks. Not what I wanted to hear but that gets me closer to buying the ECU. Expensive but that figures right. Thanks again
1 - 15 of 15 Posts
