I have gas in my oil in my 03 forman ruby 500 gonna drain oil and check carb from what ive been reading. Any other suggestions? Thanks
My guess would be a stuck float or stuck float needle in the carb. If this sticks open, it lets fuel through the carb into the airbox back through breather to the case. Check your fuel tank. If you have crap in the fuel tank, even after cleaning the carb it can and likely will happen again. You could add a fuel filter between the two to help, but be sure the tank is clean.
