01 TRX 350 brake problem?? HELP
1936 Views 2 Replies 2 Participants Last post by  honda_rider123
Like the title says i have a issue with my front brakes, one side is comming on but the other side isn't. i took the drum off to look and the pistons are pushing the shoes out but once you put presure on the pads they dont come out. I tryed bleading the lines but still got nothing, I changed the master cylinder and still nothing. So any infomation on how to fix this would be aprecited. Also there is no leaks in the lines, nor pistons.
Thanks, Chris
Still sounds like you have air in the system. Did you bleed the new master cylinder first before trying to bleed the wheel cylinders. If not more than likely this is where the air is in the system.
Well i had this problem before i bought the new master cylinder, i though it might of been it but its not, how do you bleed brakes the right way i hear alot of different ways but whats the correct way anybody could do it with out using vacume pumps and stuff like that.
Thanks, Chris
