Headlight Problem - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 2 (permalink) Old 12-09-2017, 10:42 PM Thread Starter
Headlight Problem
I have a 2013 recon, long story short, in the process of adding a light bar I have discovered that my factory headlight bulbs are drawing too much voltage. (Battery discharges after a night ride.)With all lights off, stator is producing 14.2 volts at the positive battery terminal while disconnected from the battery. When I turn the lights on, it drops into the low 8ís. I have checked my light bar and it only has a minimal draw (stays in the 13ís). I have cleaned the ground where the electrical system grounds to the frame with no improvement. I have also checked the wiring between the lights. I am getting 14.2 volts up to the connector for the wiring harness for the lights.Does anyone know why these bulbs are drawing so much voltage and what can be done to remedy the problem. I would love to upgrade to some led bulbs which I think would reduce the voltage draw, but so far I havenít been able to find any.
post #2 of 2 (permalink) Old 12-12-2017, 12:20 PM
jeepwm69's Avatar
Garage
Welcome to the forum.
My first question would be are the factory headlight bulb really factory, or could they be some aftermarket high wattage bulbs?
I'd also be interested to know if you unhook one or the other what happens to your readings.
2005 Foreman Rubicon Camo
Perfex, 27" Mudbugs
5K Viper Max winch
2009 Foreman 500FM Green
Perfex with HL springs
27" Execs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
Headlight Problem Matt3xx Foreman 500 20 02-23-2017 08:57 PM
Headlight Problem 450foreman04 Foreman 450 8 05-30-2012 09:47 PM
Headlight and display light problem hughesnp Foreman 500 17 05-12-2012 08:51 PM
'97 Foreman Lower headlight problem ecotecpwr04 Foreman 400 3 02-25-2012 10:30 PM
Replacement Main Headlight Bulb ? flipstick Foreman ATV Accessories 22 09-21-2005 01:24 PM
You may post new threads
You may post replies
