front brake master cylinder - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 20 (permalink) Old 10-15-2010, 02:26 AM Thread Starter
rc51's Avatar
Has anyone striped out the two little screws that hold the cap on? I have striped the two screws and can not get the cover off. Does anyone have any ideas how to remove the 2 striped screws?
2015 Honda Rubicon
1979 Honda ATC 110
rc51 is offline
post #2 of 20 (permalink) Old 10-15-2010, 09:59 AM
Administrator
toodeep's Avatar
Garage
I use a impact driver (screw driver you hit with a hammer) to get them most of the time. If they are really stripped then I use a small chisel to work them loose. The really bad ones (nothing else works) I drill the head of the screw off and then remove the threaded end.
1987 350D (work in progress)
toodeep is offline
post #3 of 20 (permalink) Old 10-15-2010, 11:09 AM
Honda Lover
FloatingForeman's Avatar
my stripped out and i used the little "Grab It" Tool to get them out then tapped it out to a bigger thread and used a screw with allen on the end
-Honda Rancher 350-
-Wiseco Piston-
-Kenda Executioners-
-Super ATV Disc Brake Kit-
-Uni Fliter-
-DPK Clutch Kit-
-Custom Snorkel-
-Jets-R-Us Jet Kit-
FloatingForeman is offline
post #4 of 20 (permalink) Old 10-15-2010, 01:46 PM Thread Starter
rc51's Avatar
Quote:
I never had to take them off till I got my new front brake conversion. Which I had to add brake fluid. Ya it's pretty bad. I'm going to drill them out and do something diffrent.
2015 Honda Rubicon
1979 Honda ATC 110
rc51 is offline
post #5 of 20 (permalink) Old 10-15-2010, 05:21 PM
Kipes's Avatar
Just drill the heads off and you can probably grab the piece sticking out with a pair of vise grips and get them out. I wouldnt drill them all the way out.
2006 Foreman 4x4 500s
Powermadd handguards
2.5 Warn winch
2" Perfex long travel lift kit
High Lifter springs
26-11-12 Sedona Ripsaws on rear
26-9-12 Sedona Ripsaws on front
Douglas Rattlesnake rims
3rd Headlight switch
Moose Heated Handgrips and thumb warmer
Replaced the stock silver engine covers and front skid plate with 07 camo black and painted front brush guard black
2005 Rancher 350ES 2wd
Kipes is offline
post #6 of 20 (permalink) Old 10-15-2010, 05:25 PM
Kipes's Avatar
Wouldnt hurt to put a layer of silicone on the new ones so the water cant get in either and rust up again.
2.5 Warn winch
High Lifter springs
Kipes is offline
post #7 of 20 (permalink) Old 10-15-2010, 08:10 PM
Wingman's Avatar
Toodeeps last suggestion is what I always do.
The screws are junk anyway so just drill the heads off of them and go and get new screws.
Honda 1998 Foreman 450s (Starburst Yellow)
SS ATV 2in lift
Maxxis Bighorn 2.0 tires
Aluminum Products Bash plate
Viper 3500 winch & Cycle country 52in plow
ES floorboard conversion
HONDA!!! No Wing! No Prayer!!
Wingman is offline
post #8 of 20 (permalink) Old 10-16-2010, 01:12 AM Thread Starter
rc51's Avatar
I'm going to drill them out and put some socket head cap screws in its spot. I never did like those **** things.
2015 Honda Rubicon
1979 Honda ATC 110
rc51 is offline
post #9 of 20 (permalink) Old 10-16-2010, 01:13 AM Thread Starter
rc51's Avatar
Anyone have the disc brake swap on there ruby? I need a pic of where you ran your brake line? Plans do not show where the brake line is suppose to go.
2015 Honda Rubicon
1979 Honda ATC 110
rc51 is offline
post #10 of 20 (permalink) Old 10-16-2010, 01:42 AM Thread Starter
rc51's Avatar
Also noticed that i have play in my upper a-arm bushings. Is there a rebuild kit for the a-arms? As long as I have her apart I'm going to replace the bushings.
2015 Honda Rubicon
1979 Honda ATC 110
rc51 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
350 rancher brake master cylinder rancher350la For Sale 0 07-30-2014 01:05 AM
Front brake master cylinder Jeremy450rider Foreman 450 6 10-13-2012 10:24 PM
Front Brake Master Cylinder? 4menator Foreman 500 6 05-12-2009 01:48 PM
master cylinder rebuild moakes Foreman 450 3 04-27-2007 01:34 PM
You may post new threads
You may post replies
