Stripped out oil drain plug - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 2Likes
post #1 of 14 (permalink) Old 11-05-2007, 04:17 PM Thread Starter
Well, I stripped out one of the oil drain plug screws on my 07 Rubicon... any thoughts on repairing this? I bought a new bolt and it still seeps out a little bit. Any thoughts??
I thought about retapping the whole to a 13mm and calling it a day but i am worried about getting metal shavings inside the the crankcase? I tried to use a thread repair kit but the bolt doesn't appear to be any real common size 12mm bolt. I tried 12mmx1.25 12mmx1.5 and 12mmx1.75.. none of which match up to the bolt.
I really don't want to have to split the case. Is there some sort of trick to repairing this thing? Or Am i just S.O.L.???
2007 420 Rancher
2" Lift
27" ZILLAs
ITP 12" Wheels
Stick Guards
HMF Programmer
HMF Utility Exhaust
Rear Bumper
surelly09 is offline
post #2 of 14 (permalink) Old 11-05-2007, 07:53 PM
you can re-tap the hole just put alot of grease on the tap and the shaving will stay attached to the tap. you aren't working with steel snug is more then good enough on 90% of the bike
07 Honda Rubicon
HL Clutch Kit
Mud Buster Cam
HMF Pipe
Custom Radio Box
Jet Kit
HL Springs
HL Lift
Recoil Cover
Custom Snorkel and all vent lines ran to snorkle
28" outlaws
gorilla axel!
Hot wired fan to switch
rear wheel spacers
HL temp gauge
HL full skid plate pachjage
new strong made rear bumer
heat guard
hondaman5002002 is offline
post #3 of 14 (permalink) Old 11-05-2007, 10:46 PM
Honda Lover
Send a message via MSN to RubiconManr
can u put like an o-ring or gasket around the new bolt.
might that work.
2004 Honda Rubicon
Windshield
Warn 2.5ci
Modded Kawasaki KX250F Stock Exhaust
26" Maxxis Zillas
_________________________________
1982 Honda ATC 200
In Process Of Rebuilding
RubiconManr is offline
post #4 of 14 (permalink) Old 11-06-2007, 08:20 AM Thread Starter
Well I have a thread restorer kit and i am going to try and use it first. found some brass washers with rubber in the center around the bolt and that is where it is leaking, I'm going to try that. If that fails i will be drilling and heli-coiling it.
2007 420 Rancher
2" Lift
27" ZILLAs
ITP 12" Wheels
Stick Guards
HMF Programmer
HMF Utility Exhaust
Rear Bumper
post #5 of 14 (permalink) Old 11-06-2007, 09:29 AM
Honda Mechanic's Avatar
We use Heli-coils for all stripped drain plugs except 2000-06 TRX350 we use insert for them ...
Honda Mechanic is offline
post #6 of 14 (permalink) Old 11-06-2007, 02:05 PM Thread Starter
how much do you usually charge for sometihng like that???
2007 420 Rancher
2" Lift
27" ZILLAs
ITP 12" Wheels
Stick Guards
HMF Programmer
HMF Utility Exhaust
Rear Bumper
post #7 of 14 (permalink) Old 11-06-2007, 04:14 PM
Our shop charges $10.00 per hole ..
post #8 of 14 (permalink) Old 11-06-2007, 04:35 PM Thread Starter
well dang.. i may just take it in and have it done...
2007 420 Rancher
2" Lift
27" ZILLAs
ITP 12" Wheels
Stick Guards
HMF Programmer
HMF Utility Exhaust
Rear Bumper
post #9 of 14 (permalink) Old 04-15-2019, 12:19 PM
jeepwm69's Avatar
Garage
Well my father in law's 06 was stolen some time last fall (not sure exactly when, as it was in storage and he just discovered it was missing a couple of weeks ago).
Got the ignition switch replaced, but went to change the fluids and the rear drain plug is stripped.
Is there enough metal in the Rubicon crankcase in that area to drill oversize and tap one size up, or maybe even add a helicoil? @toodeep @harig
2009 Foreman 500FM Green
27" Execs on Rubicon rims, Perfex
5K Viper Max winch
Perfex with HL springs
27" Mudbugs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
post #10 of 14 (permalink) Old 04-15-2019, 12:36 PM
Administrator
toodeep's Avatar
Garage
Yes, I've oversized them to the 14mm drain plugs with zero issues.
jeepwm69 likes this.
1987 350D (work in progress)
toodeep is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Similar Threads
stripped oil drain plug brutus750i Honda Rancher 350, 400 & 420 4 01-06-2014 03:15 PM
stripped drain plug dieselmudder How-To 14 09-18-2010 10:54 PM
Stripped Oil drain Plug steve1954 Foreman 450 2 05-10-2009 07:33 PM
stripped drain plug YellowForeman123 Foreman 500 2 04-05-2009 11:45 AM
stripped drain plug YellowForeman123 Foreman 500 5 04-03-2009 10:17 PM
You may post new threads
You may post replies
