01 Rubicon shift problems - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 5 (permalink) Old 10-21-2019, 01:33 AM Thread Starter
I am getting the D1, D2, and ESP flashing , I talked to the dealer where I bought my 01 new, this is the 1st issues with this since new and I have called to dealers and not much help other then bring it in and we will check it out! Not at $94.00 an hour. I can do the ad the parts to it tell the problem goes away a lot cheaper. I have replaced the ECM, Shift motor, and the Angle sensor like the dealer said that Honda said to do. Got everything working the way it was suppose to. Took it for a test drive and when I got to 11mph the problem came back, slow and sputters in Rev. Did the OHM test on the Angle sen. and tested the shift motor off the trans plugged into the harness and it all worked and checked out good like the book said. Can anyone help?
post #2 of 5 (permalink) Old 10-21-2019, 09:09 PM
Forman500Rubicon's Avatar
Does it change into Forward & Rev, Neutral and Low ok? And will it go thru the gears ok in ESP?
Forman500Rubicon is offline
post #3 of 5 (permalink) Old 10-21-2019, 11:53 PM Thread Starter
No it will not change gears in ESP mode or while in drive. I stays in 1 gear
post #4 of 5 (permalink) Old 10-22-2019, 12:40 PM
Sounds like you have a failed Hondamatic transmission, pretty common on the first generation Rubicons.
spock is offline
post #5 of 5 (permalink) Old 10-23-2019, 07:13 PM
martdog420's Avatar
https://drive.google.com/drive/folde...pf?direction=a
read the trouble shoot section and check for error codes 1st.
2006 Rubicon Canadian Trail Edition.
1 1/2 inch Quadrax lift
26" Mudlites
Motovan B series back seat
2500# warn
1000's of custom scratches
100's of dings n dents
50+ plastic stitches
and a few oil changes.
martdog420 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
