Snow Plow Blade Length - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 2Likes
post #1 of 12 (permalink) Old 10-20-2019, 02:52 PM Thread Starter
Researching options for a snow plow system for my 2004 Rancher 350 ES. I've heard a 60" blade clears a path for the wheels which makes plowing easier. I've also heard that a 350 isn't enough power for a 60" blade. A smaller blade seems reasonable but do the wheels bog down in the smaller path? Also most systems I've looked at are similar in price. Any recommendations? Thanks
J. Ricks is offline
post #2 of 12 (permalink) Old 10-20-2019, 06:59 PM
Honda Lover
I have a 60" on my 300 king quad, works great.
2017 trx500 fm6
Trout Brook Rider is offline
post #3 of 12 (permalink) Old 10-20-2019, 09:16 PM
Forman500Rubicon's Avatar
I had a 48” snow plow on my old 350, it worked great & used it for many years. I now have a 54” tapered blade that I use on my Rubicon and Kodiak. You won’t have any issues with a 48” blade, to be safe I wouldn’t go any wider on yours.
ID:	41965   Click image for larger version
Forman500Rubicon is offline
post #4 of 12 (permalink) Old 10-20-2019, 09:23 PM
mrbb's Avatar
I believe a 350 has plenty of power to push a 60 inch blade, as long as your not running extra tall tires that is
the name of the game in plowing with a ATV is NOT waiting for snow to get too deep to move it easily,
staying on top of it with a few plows, is better than trying to move all in one deep snow fall! or in very WET heavy snows
MOST atv's on STOCK sized wheels will run out of traction before they run out of power to push things, so a 60 inch blade will be fine IMO, my 400 has pushed snow for 20 yrs with a 60 on it, never ever wished I had a smaller blade, MANY times I wish I had larger though!
and NOT all atv plow set up's are the same, some are rather cheesy and some better built
some are more user friendly and some are more simple and stronger due to it, but less user friendly!(well taking on and off bothers some with mid mounts)
MOST all atv's tend to need better shocks up front when adding a plow blade too
szyg6h likes this.
mrbb is offline
post #5 of 12 (permalink) Old 10-20-2019, 09:43 PM
Administrator
toodeep's Avatar
Garage
54/55 is the largest I would go on a 350. Power has nothing to do with it but weight does. If you have a heavy wet snow it's just going to spin you sideways when angled. I've used my 72 on my 420 rancher in light snow but it was an overkill for the machine.
2013 MUV 700----2011TRX500FPM----2009TRX420FPA----2009TRX420FA----2007 TRX420FM----2006 TRX400FA----1995TRX300FW----1988TRX350D----1988TRX300---1974 CB750 Amen Savior Chopper----!974 ST90
toodeep is offline
post #6 of 12 (permalink) Old 10-21-2019, 05:15 PM
mrbb's Avatar
you can always add weight if needed
in 20+ inch snow falls I have had to add 250+ lbs to push things, still had power though, weight was more for me for traction, and I might be wrong but I DON"T think a 400 foreman and a 350 have much difference in overall weight>
believe a 350 has lower gearing though, which would only help it push(minus not saying weight doesn't matter) but lower gearing allows for easy pushing /wear and tear on machine
Think tractor like deal!
mrbb is offline
post #7 of 12 (permalink) Old 10-21-2019, 09:01 PM
I never had trouble pushing 20+ inches of snow with my old 350 and a 48” plow And never added weight to the rear; but I know I would have with a bigger plow. Putting a 60” plow on a 350 will also add much more weight to the front making the rear lift. With a 60” plow I would recommend a larger winch also like a 3500. A 2500 will be fine most of the time but my 2500 on my Rubicon struggles a little when there is a lot of wet heavy snow but the the 3500 on my Kodiak has no problems.
post #8 of 12 (permalink) Old 10-22-2019, 11:14 AM
mrbb's Avatar
Quote:
OK please take this as info and not a bash or ??
but you do NOT need a 3500 lb winch to lift a plow blade, odds are a 500 lbs winch will lift it with any snow , as your NOT getting enough weight on a BLADE no matter how wet the snow is, plow blades really don;'t hold much snow. a larger winch will just draw more power and run a battery down more and tax your charging system
Now a 60 inch blade will add more weight to front end when traveling with blade UP, but the amount of weight savings from a 50 to a 60 inch blade is NOT that much, MAYBE 5-10 lbs difference if that?
so your splitting hairs , and again MOST atv's benefit from better shocks when you add a plow, to handle all the new added weight!
just s aa pickup truck will, to handle plow weight better!
ALL the more so when its a full front mount plow set up over a mid mount set yup(mid mounts help displace weight better by being under the middle of the atv as a fulcrum point, so less weight is actually on the front end at times, where a front mount , its ALL On the front end!
a 54-55 inch blade might be the more perfect size, but there harder to find and less selection of them IMO
I plow a lot, a few hundred miles a yr on my atv!
and many more with trucks, tractors, backhoes and skid steers
ATV will plow a lot more than most folks think they will!
mrbb is offline
post #9 of 12 (permalink) Old 10-22-2019, 01:22 PM
Honda Lover
I have a 2000lb winch on my 60" blade
2017 trx500 fm6
post #10 of 12 (permalink) Old 10-22-2019, 01:41 PM
Administrator
toodeep's Avatar
Garage
I use my winch for more than just plowing so I get one enough to pull out the machine. I get hard packed, wind blown snow so blade with is important to me. Other factors are moving snow around buildings with limited space, sidewalks and so on. All of this needs to be factored in to get what is best for the user. I have a 72 on my bigred muv, 60 on my 500 foreman.
I bragged up moose plows for years and still do. My 72 has lasted 2 years and was about junk. I rebuilt it in hopes of getting 2 more years out of it. My 60 has lasted over 10 years with only a bent push tube (my fault). I use them hard and for everything so they see use and abuse.
I will add I wish my 60 was a 50 or 55 for what I use it for now. It mostly gets used for gravel and tight area snow removal. I have the sxs for the open areas and it has heat.. lol
toodeep is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
