2009 Rancher...hit the gas and i2009 Rancher...hit the gas ant sputters, help please. - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 3Likes
  • 3 Post By NHRancher
post #1 of 6 (permalink) Old 09-05-2019, 12:30 PM Thread Starter
Hi friends, so I have a 2009 Honda Rancher 420 4x4 electric shift (not the dual clutch auto). The problem is very odd, in short; Turn motor on, shift from neutral to first gear, hit the throttle and it sputters. Drop it back into neutral, rev it, shift back to first and it no longer sputters. Any ideas and next steps would be greatly appreciated.
Thank you.
NHRancher is offline
post #2 of 6 (permalink) Old 09-05-2019, 01:10 PM
Honda Lover
Is this problem duplicated every single time? Sounds like you have trash in your carburetor.
2007 Foreman 500FM
2014 Foreman 500FM
Service Manuals Link: https://drive.google.com/drive/folde...7LP-eZp2jMRVJU
Wilbur is offline
post #3 of 6 (permalink) Old 09-05-2019, 01:18 PM Thread Starter
Yes it happens every time no matter how long I wait between rides.
Reading on here it seems likely it could be the fuel pump/filter so this weekend I plan to
1. Clean or replace the fuel filter
2. Clean or replace the petcock strainer
3. Clean or replace the fuel injector
4. Clean and inspect the fuel lines as well as the fuel tank vent cap/tube
5. Test and if needed replace the battery
post #4 of 6 (permalink) Old 09-05-2019, 01:35 PM
Administrator
toodeep's Avatar
Garage
Are you starting it in gear or neutral? Almost sounds like one that's started in gear and the front brake lever doesnt return far enough to close the switch.
1987 350D (work in progress)
toodeep is offline
post #5 of 6 (permalink) Old 09-09-2019, 01:33 PM Thread Starter
Following up to my main post.
Went through the entire fuel system over the weekend, cleaned the petcock, cleaned fuel lines, cleaned the injector (took out and sprayed injector cleaner through it while applying 12v to the leads to activate the injector). Thing runs great now. In the end I am almost 100% certain it was mostly the fuel filter when I took it out it was black and filled with debris.
Thanks again for all the suggestions.
post #6 of 6 (permalink) Old 09-11-2019, 07:39 AM
Honda Lover
Appreciate you coming back and updating us with the solution so we can better help next time.
2007 Foreman 500FM
2014 Foreman 500FM
Wilbur is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
