carb bowl hose on bottom - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
 8Likes
  • 2 Post By jeepwm69
  • 1 Post By jeepwm69
  • 1 Post By toodeep
  • 2 Post By Moccasin Ranger
  • 1 Post By bcsman
post #1 of 10 (permalink) Old 08-25-2019, 11:09 AM Thread Starter
the carb bowl hose that connects on bottom where does it connect to or go 2002
js304336 is offline
post #2 of 10 (permalink) Old 08-25-2019, 12:30 PM
Honda Lover
Are you referring to the drain hose?
2017 trx500 fm6
Trout Brook Rider is offline
post #3 of 10 (permalink) Old 08-26-2019, 01:28 PM
jeepwm69's Avatar
Garage
If it's the drain hose it just hangs. It's there so if your carb float sticks open the gas runs out onto the ground instead of running into your crankcase and filling your engine with gas.
2005 Foreman Rubicon Camo
Perfex, 27" Mudbugs
5K Viper Max winch
2009 Foreman 500FM Green
Perfex with HL springs
27" Execs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
2006 Foreman 500FM Green
3K Superwinch winch
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is online now
post #4 of 10 (permalink) Old 11-06-2019, 10:30 PM
pg@profpg.com's Avatar
carb drain running....How do you fix it? do you replace the float?
post #5 of 10 (permalink) Old 11-07-2019, 12:25 PM
jeepwm69's Avatar
Garage
Quote:
Need to clean your carb and make sure there's not trash keeping the needle from sealing, but the 350 Ranchers are HORRIBLE about leaky carbs.
Try polishing the seat with some polishing compound on a qtip (I chuck mine in my drill and run on low speed). You might need a new float needle too.
[email protected] likes this.
Perfex, 27" Mudbugs
5K Viper Max winch
4K Viper Max winch
3K Superwinch winch
post #6 of 10 (permalink) Old 11-07-2019, 09:11 PM
sounds good. I'll try to get the carb off.
thank you
post #7 of 10 (permalink) Old 11-08-2019, 01:13 PM
jeepwm69's Avatar
Garage
Might be able to do it without removing the carb.
I've unhooked the choke and throttle cable, loosened the hose clamps, and spun a carb upside down before to work on it (got tired of taking everything apart over and over again on a troublesome carb). That was on a 500 though. Not sure if there's room to spin it on a 350.
Perfex, 27" Mudbugs
5K Viper Max winch
4K Viper Max winch
3K Superwinch winch
post #8 of 10 (permalink) Old 11-08-2019, 02:28 PM
Administrator
toodeep's Avatar
Garage
On the 350 it's easiest to get the air box out of the way (2 hose clamps, breather hose and a nut on the bottom. Even then there isn't a lot of room to mess with things since the cables are tight.
2013 MUV 700----2011TRX500FPM----2009TRX420FPA----2009TRX420FA----2007 TRX420FM----2006 TRX400FA----1995TRX300FW----1988TRX350D----1988TRX300---1974 CB750 Amen Savior Chopper----!974 ST90
toodeep is online now
post #9 of 10 (permalink) Old 11-08-2019, 02:36 PM
Honda Lover
Sometimes the long brass tube that feeds the overflow will crack. Then it flows all the time with normal fuel level in the bowl. People will over-tighten the drain screw trying to stop the flow, and that just bends the the tip of the screw., then it won't close.
Moccasin Ranger is online now
post #10 of 10 (permalink) Old 11-08-2019, 04:43 PM
Honda Addict
bcsman's Avatar
First make sure the drain screw on the bottom is tight, forgot to tighten mine once and fuel leaked. Second I kept getting fuel leaking out the overflow hose and did what was mentioned above. Happened 2-3 times and ran some fuel into a white coffee filter, was getting a few small pieces of sediment. So even after cleaning the carb a little sediment would get in there and keep the needle from closing. I need to take the tank off and clean well but will wait until next warmer weather so I put an inline fuel filter on. Been a couple weeks and so far not a drop when shutting off....
1998 Honda Foreman 450ES`
bcsman is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
